The dimensions from the 3D model shown in the draiwng is editable in Creo 2.0. It can be deleted easily with single click and delete button.
Is there a way to lock the dimensions from getting deleted so easily?
Welcome to the forum, Nirmal.
Deletion is not permanent from the drawing. You can easily show it again with show annotation.
No.
