I'm wondering what are the differences between Bahavioral modeling and Mechanism Dynamics.
I din't find clear answer on Ptc website.
Thanks for any explanation or web link.
GB
Georges,
BMX is the Behavioral Modeling Extension and can be used to perform sensitivity studies or optimizations using parameters or dimensions as inputs and anything measurable as outputs. It can be used in regular assembly or part mode, or in a mechanism.
MDX is the Mechanism Dynamics Extension which adds to the built-in Mechanism Design capabilities. It allows for evaluation of forces and other "dynamic" properties of a mechanism. You might use BMX and MDX together or separately. This is also called MDO (Mechanism Dynamics Option)
I'm sure you found this info on PTC's site, but for anyone else that's wondering -
http://www.ptc.com/products/creo/behavioral-modeling-extension
http://www.ptc.com/products/creo/mechanism-dynamics-extension
