"Sebastian Hohenauer" wrote:
Hi! I already posted a simmilar problem with threads in the 2D-view. But now another one emerged: If I add a cross section in another cross section by usind a spline, suddenly nearly every thread in the whole asembly is displayed. (which means, that not only the things which are displayed in the cross section have their threads, but also the screws which are behind the plain, on which the cross section was created) This is not a problem of my own, but nearly my whole class has the same problem. We are using the schools edition of pro engineer. I hope I described it on a comprehensible way... Thank you for your answers. Sebastian H.
hm, no I'm sorry. didn't work. I've uploaded a screenshot for visualising my problem. on the left side the spline is activated, on the right side, I deleated it again. I marked the thread, which appears when adding the cross section. (ignore the other display errors on the right pic. I don't know, why they have happened...)
yeah, i also thought of a bug... can xou tell me, where to post the bug, so it maybe will be fixed in the next version? I think you could open it, but at the moment you change anything, I won't be able to open it^^ Thank you for your help Martin. (By the way: do you know, if it is possible to set a picture as background in the 2d-drawing? for example a picture of the 3d-model? It would be "just for fun", so it wouldn't be a problem, if there is no easy way
