divide at intersection
ClearBlueSky85
3-Newcomer
What happened to divide at intersection in Creo 2? I have two lines that intersect each other. One of the lines (the horizontal line in the picture) is already divided into two separate segments. Whenever I try the new Divide command, it does not divide the other line (the vertical line in the picture). The help says:
To create a divide at an intersection, click near the intersection and Creo Parametric automatically snaps to the intersection and creates the divide.
I don't see any way how I can control which lines it tries to divide.
Why was the divide at intersection feature removed? I also wonder what happened to the trim to bound command
1 REPLY 1
Maybe they just simplified the command by dividing at the pick location.
If that happens to be an intersection, it divides what it can.
For me, crossed lines are dividing both lines. If it is a circle, if you make 2 picks, it also divides the circle.
