I have recently run into something seeming to be a bug so see if this might be the problem...
When placing a view, I use combined states for two different views of a part, one flat pattern and one bent. For some reason, only one of the two views would follow the default scale. The other view had to be set using the properties/scale option.
I will also add that having 50 sheets to a drawing is very bold. If that file ever got corrupted, you would be in a world of hurt. I've already had drawing corruption using datum tag annotations. Be careful!
I wonder if that scale factor is exactly 25.4...
or 2(scale) x 25.4. Could it be that there is a SAE to SI issue somewhere in the model?
What date code and version are you using?
Can you submit this to PTC support for evaluation?
This is the kind of corruption I was refering to. If you redefine these views, will they remain stable of willthey again corrupt themselves?
It is very important that these files find their way back to PTC for resolution. They can't fix something they don't know about.
You can go to the PTC update advisor to see if there is any bug like this reported before.
You need an account to access this but the information can be helpful:
https://www.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
Just plug in the comparison and it will spit out a lot of data. There is a second tab to show what issues have been reported in the current release.
Glad you found a simple solution.
If you click on the Review tab in the ribbon when a drawing is open, you will see Update right below regenrate along with another view update options. I think the right click might be better as it only updates the sheet you are currently on.
I remember in 2000i, there use to be a "Regenerate: Draft". These update options must have replaced this. I never really noticed they did anything, but now we know 🙂
