drawings of family table parts
ptc-115892
I have a part with different family table instances and I want to create individual drawings of each instance. Is there a way to do this without creating a new drawing over and over, dimensioning each one from scratch?
Regards: Larry
6 REPLIES 6
yes,
create the first drawing, copy the drawing over and then replace the model
with the next instance
bingo!
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
Sure. Create the first drawing & fully dimension it, create all views, etc.
Then do a Save As on the drawing.
Open the new drawing, RMB in the background (ie not on a view) > Properties
> Drawing Models > Replace > Select the instance you want. Save it. Done .
(works in WF2 & WF3 - I don't' know about other versions).
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
I think what Robert meant is to do a SaveAs to the new drawing name, then
switch the models.
The only problem I know of with that is, at one time you couldn't repeat
dimensions on more than one drawing, because of maintaining all of the
drawings tied to that generic model. I am not sure if that was a bug at
that time, but because we use tabulated drawings it has never been an
issue for us.
Brian S. Lynn
Technical Coordinator, Product Engineering
Yes Larry, you are correct, I answered a bit too quickly. Save as is the
correct technique. Also a few words of caution. If you are using shown
dimensions be aware that any change to them will of course propagate
through the family of drawings. For created dimensions, (no debates
please) the default is that the dimensions get stored with the model. If
you create a dimension on drawing -001 and delete that dimension on
drawing -002. the dimension will also be deleted from drawing -001. Use
erase instead of delete and you will not have this problem.
Bob Frindt
Sr. Designer
Parker Aerospace
You can switch the model and "Save As" or you can insert this table and have a tabulated drawing.
In Reply to Larry Matier:
Regards: Larry
Michael R. Jenkins P.E.
Design Engineer
Direct: 816-801-2332
Fax: 816-891-9432
Commercial Vehicle Systems
Haldex Brake Products Corporation
10930 North Pomona Avenue
Kansas City, MO 64153-1215
I just tried this trick. It works fine except that my dimensions (shown) all disappear once I replace the parts. Any idea why?
