In Creo web-support says, that the section files in palette may have either extension .sec or .dxf. With extension .sec everything is clear. However, with .dxf files I have a problem. Palette does not see .dxf files. I tryed different versions. But nothing happend. Maybe someone have a solution, how to use dxf in palette?
Nice to know and I did not realize we could do that.
Your bug however is an issue.
Just for grins... did you try upper v. lower case extension?
Of course, no spaces in the file name?
I'll have to look at that but do create a support case if you can.
That way you know if there are known issues quickly.
I tryed 1.dxf and 1.DXF, but still nothing(
Unfortunatly, I can't create a support case right now.
What Creo version are you using? Are you sure .dxf files can be used in the sketcher palettes? I tried in Creo 2.0 and it does not work. So maybe this functionality is only available for Creo 5.0....
I work in Creo 4.0 M040.
In HelpCenter of Creo 4.0 sais the same about .sec and .dxf in palette.
