Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Ok - Really missing the drag handles on the drawing dimensions. I need change the elbow length of the leader on a shown diameter dimension. How you do dat? Creo 2.0 m40
