file naming question
fdefilippi
I don't understand why I'm getting this error.  I want to create a drawing of this part and the same directory with the same name, but there is not existing drawing in the same directory.    Frank
Hello Frank,
It must be in assignment and you can not store under the same name.
Go in Save as.
Kind regards.
Denis
StephenW
(To:fdefilippi)
it could be in memory...check file open in session
it could be in the working directory...check file open working directory
it could be in the search path...check file open and just key in the name and add the .drw  (4001_310_00422.drw)
also check the window home folder... my documents or user folder
