flexibility not visible when dragging components
EB_11159537
3-Newcomer
In Creo, flexible components such as springs, mounted in an assembly, do not graphically show their flexibility when dragging. How to solve this behavior? What can I do? And without using the mechanism! In short, I would like to see the spring that stretches and compresses when I drag the purple component without having to regenerate at the end of the drag. thanks in advance to anyone who can help me
starting position
after dragging the purple component
after regenerated
 Creo cannot flex components as you drag them.  A regeneration is required to take the measurement and update the the flexed model.
If creo was constantly regenerating to keep up with the drag, performance would be greatly impacted.
2 REPLIES 2
Hi @EB_11159537,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
