The new web interface is very different and has cause several issues when installing or upgrading Creo Parametric. It's a little confusing on how to stop the server correctly because it's burried in a section you would not know to look in. If you stop the server with the option in the main UI, it will shutdown the server and it will not restart. This has cause issues when I am remotely working on license servers.
There is also a problem on how you choose your license file when installing Creo Parametric. You must drag and drop the license file on the installation UI rather than just typing out the license server address. If you type out the license server address, it will create a new license folder that does not work and you must manually correct this by deleting that folder and copy the license file into the correct one. If you drag the license file on the UI, it will work as intended. You must also drag the license file from the desktop or a local folder, if you attempt to do this from a network location, it will hang up the application.
It's been a challenge to learn this new interface, but now I understand it fairly well. At first I wanted to toss my computer out the window.
ΜΟΛΩΝ ΛΑΒΕ
