I am on wild fire 2.0 and I am in the process of building a "format" for drawing. I have been building other documents using parametric parameters with good sucess. I am not sure if I have "pro_detail" but I dont see it in pro status when I run it. I built the whole entire template fir the format an I only need to add the driving parameters. I can put them in the format but when I go to use it the are not pulliung the data from the model.
Thamks
I figured out my issue. The information on how to input parameters is a little miss-leading, it says "can be placed on a format as a text in a table cell or as a note". I input the parameters as a note by creating the note and dragging the note onto thetable. This note is not in the table in this manor.Iadd the parameters into the table by double clicking the table cell and adding the parameter to the cell.
In Reply to Terry Thomas:
Thamks
Wrap onto cylinder
on tangent plane, create sketch from wrapped curves with 'use edge' tool
use the sketch in offset surface feature - side surfaces normal
This method can be used for 'wrapping' onto non cylinder 3d surfaces by wrapping onto a cylinder which approxiamates the 3d surface
