global interference check shows wrong interference value
rohit_rajan
i have two parts which are assembled together. just to confirm whether there is interference between the two parts when i do a global interefrence check it shows the total volume of the two parts as interefering..how is that possible?....creo elements/pro 5.0...
3 REPLIES 3
Rohit,
can you upload data files?
Martin Hanak
Martin Hanák
i don't think it would be possible to upload the assembly or part files...
the good news is that this happens in creo elements/pro 5.0 ...but it is fine in creo 2.0 parametric.
gkoch
(To:rohit_rajan)
Hello Rohit,
can you post the datecodes of Creo Elements/Pro 5.0 and Creo Parametric 2.0 you have tested?
In case someone has a similar issue, it can be interesting to know, with which build the issue has been resolved (it does not necessarily have to be the first customer shipment of Creo 2.0 (F000), which solved it)
Thank you,
Gunter
