groundwasher
Redro
groundwasher
Hello i want to design a ribbed washer but i don't know how i made this
Please take me sugestions
thanks
Gucio
(To:Redro)
hi,
please look at the sample. I did it in Creo 3.0
regards,
gucio
Krzysztof
6 REPLIES 6
Hello Bogdan,
Are you using Creo, Windchill, or another PTC product?
You have posted your question in the PTC Integrity forums, and there is no truly useful was to design a washer within this product, but I can move the discussion to the appropraite forum, if you let me know which product it is for.
Kael
Kind Regards,
Kael Lizak
Redro
(To:KaelLizak)
i use creo
sorry i see as posted in a wrong place
please redirect my post or delete
ReinhardN
(To:Redro)
Hello Bogdan
in the assembly only the compressed state is important (teeth are flat).
I would model the washer with patterned cuts on the outside or patterned cosmetic sketches. Bent teeth will only affect performance.
Reinhard
ClintWalton
(To:Redro)
Hi Bogdan,
Can you describe the geometry in further detail? Are you looking to make a lock washer? Including a photo is often helpful for other users to visualize what you're describing.
For the washer in your photo, I'd suggest creating the ring (extrude a sketch with 2 concentric circles) as the first feature, then create one tooth, and then pattern that tooth around the ring. The tooth will be the only tricky part; you will probably want to use a sweep feature.
Gucio
(To:Redro)
hi,
regards,
gucio
Krzysztof
