help with pattern point on a spline
JMSCRA
All,
I can pattern a point on a spline as a ratio or as a actual length. Works good. But, what I want to do set it up so that when the spline length changes the pattern changes so the number of points at an actual length changes when/if required. I would write a relation but I do not have a dimension that is for the actual length of the spline. I can measure the spline but that doesn't give me anything to use in a relation.
Lost in pattern land.
John M. Scranton
Senior Designer
Ultra USSI
4578 E. Park 30 Dr.
Columbia City, IN 46725-8869
*Vioce: 260.248.3576
*Fax; 260.248.3509
[cid:image001.jpg@01CA1CDD.2E2112B0]
dgschaefer
(To:JMSCRA)
Create an analysis feature to measure the spline length. This will give
you a feature parameter that you can use in a relation.
Doug Schaefer
LinkedIn
