hole dimensions are mixing
ptc-2774843
Please see attached file, it is 2" bspp hole. Which is dimentioned by address values in drawing. If I am giving dimension in top view then it is comming correct in pdf as you can see. But if I am giving dimension in section view then dimension values are merging as you can see in attached pdf. Some times I require to give hole dimensions to section view. Can any one tell some solution of this problem.
Is the Drill and Tap note coming from default format or custom?
