horizontal leader line missing after changing drawing units from inch to mm
hvyas-3
7-Bedrock
Hi Creo Community,
 I have converted the creo drawing file units from inch to mm. upon doing so the fonts of all the text got very minute and smaller. I have fixed it by updating the text values to mm equivalent of inch.
However still in diameter and radius dimensions the horizontal leader line is missing. See attached image. I have highlighted in red.
I would appreciate your help with your suggestion on how I could show it back?
Thanks so much!
kdirth
(To:hvyas-3)
That looks like dim_text_gap in the DTL has a large value.
8 REPLIES 8
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
http://kotom.eng.free.fr
BenLoosli
(To:hvyas-3)
It might be the Leader_Elbow_Length in your DTL file settings.
Thank you!
I tried to change Leader_Elbow_Length but it doesn't make any difference in this particular situation.
kdirth
(To:hvyas-3)
It may be that the length of the horizontal leader was adjusted.  Can you hold Shift and drag it out to show a horizontal leader?
hvyas-3
7-Bedrock
(To:kdirth)
Thank you!
I tried to move the dimension to right holding shift. The horizontal leader line did show up but the dimenison moved to further right creating a long distance between leader and the dimension value. (see attached image)
Cab you please advise how to bring this dimension near to leader keeping the horizontal leader line.
kdirth
(To:hvyas-3)
mkajdan
(To:hvyas-3)
Select the dimension then hold down the SHIFT key to drag the dimensions left or right.  This should expose the missing leader line.
hvyas-3
7-Bedrock
(To:mkajdan)
Thank you!
