how do I find the smallest radius on a model?
Sean
I am looking for a tool that will analyze a complex model and output the size of the smallest radius feature. Does this tool exist?
You can use the Analysis - Geometry - Radius tool! First offcourse you have to maka a quilt of your solid so the analysis can consider all of the surfaces.
As Stevo pointed out , you can use the Analysis - Geometry - Radius tool. But you need not make a quilt..Just pick the model in the Model Tree.
Selecting the model from the tree worked well. Thank you for the help.
