how to check that in an assembly a *_sk* component is a skeleton and not a part ?
We want to ensure that skeleton is used in assembly, and not part renamed as a skeleton
Hi Jean
They do not have the same icon, parts and skeletons
Skeletons are always the first you have in your model tree, befor yuor datums
ES
Fully agree, but is there a way to check that automatically ? using Modelcheck for exemple
Well, that is a good question
I am not a Modelcheck guy, but I guess you have some copy geom from your skeleton, if yes you should be able to check if they comes from a skeleton or not.
Modelcheck has a lot of limitations, so you may need a Protoolkit program to do it
