how to convert a decimal numeric dimension to a fraction in an ebom drawing table
jbennett
8-Gravel
I am trying to convert a decimal numeric dimension to a fraction in an ebom drawing table. I have already added a parameter to the dimension and I am able to reference the parameter in the table. I don't want to convert the dimension in the model, only on the drawing table. How would I do that?
FV
(To:jbennett)
Hi all,
John,
You can add a relation block to implement a 'repeated multiplication by 2' algorithm.
It is kind of ugly code, but with the limited pro/relations syntax we have to use what we could.
Something like this:
test =7/64 /* replace 7/64 with dimension symbol, works for positive numbers
test0=floor(test)
test2 = mod(test,1) *2
if floor(test2) > 0
first=1
denomiator = 2
numerator = 1
else
first = 0
endif
test4 = mod( test2, 1) * 2
if floor(test4) > 0
second=1
denomiator = 4
numerator = 1*second + 2*first
else
second = 0
endif
test8 = mod( test4, 1) * 2
if floor(test8) > 0
third=1
denomiator = 8
numerator = 1*third + 2*second + 4*first
else
third = 0
endif
test16 = mod( test8, 1) * 2
if floor(test16) > 0
fourth=1
denomiator = 16
numerator = 1 * fourth + 2*third + 4*second + 8*first
else
fourth = 0
endif
test32 = mod( test16, 1) * 2
if floor(test32) > 0
fifth=1
denomiator = 32
numerator = 1*fifth + 2*fourth + 4*third + 8*second + 16*first
else
fifth = 0
endif
test64 = mod( test32, 1) * 2
if floor(test64) > 0
sixth=1
denomiator = 64
numerator = 1*sixth + 2*fifth + 4*fourth + 8*third + 16*second + 32*first
else
sixth = 0
endif
result = itos( test0) + "-" + itos( numerator) + "/" + itos(denominator) /* string representation of fractional number
HIH.
Feliks.
2 REPLIES 2
FV
(To:jbennett)
Hi all,
John,
test0=floor(test)
if floor(test2) > 0
first=1
denomiator = 2
numerator = 1
else
first = 0
endif
if floor(test4) > 0
second=1
denomiator = 4
else
second = 0
endif
if floor(test8) > 0
third=1
denomiator = 8
else
third = 0
endif
fourth=1
denomiator = 16
else
fourth = 0
endif
fifth=1
denomiator = 32
else
fifth = 0
endif
sixth=1
denomiator = 64
else
sixth = 0
endif
HIH.
Feliks.
gkoch
(To:jbennett)
Hello John,
did the answer from Feliks help you solve your issue?
If yes, please let us know, i.e. mark the answer as correct to signal the thread has been answered.
Gunter
