Is there any way how to automate similar tasks on multiple parts?
e.g. I have list of the parts (about 100 parts), and need to add sheetmetal conversion feature to each,
- to add parameter and assign it to dimension,
- to create coord.system,
- to add annotate on surface containing part's name....
- or if not exist, to create saved orientation
I know, some task can be done only with help of user (to select reference, to enter value...).
If I do that manually i need to open every part (type its name to open dialogbox), do the task, regenerate, save, close, open next part...
I would like to have automated this in such way that creo just ask for the references or to enter values for every part.
I do this partially with help of mapkeys but it could be better.. (at least automate the parts list).
I work in creo 3
thanks for reply.
Michal
Hi MIchal,
... try to check ModelCHECK configuration +batch mode.
Michal,
to automate some process you can use routine made by Jose Costa, see:
Trailmaker 0.3 - PTC Community
Re: Load multiple drawings into session at once - PTC Community
Re: Trailmaker 0.3 - PTC Community
Re: TrailMaker Script - PTC Community
-OR-
you can use AutoIt/AutoHotkey software.
Martin Hanak
thanks to Martin ... ![]()
ok, thank you, I'll look at it..
m.
