hello sir ,
please give me guide line for how to export file from creo 3.0 to nx ?
thnk u .......
You can export solids body in STEP format (".stp") and surfaces as a IGES file format (".igs") then for reading them in NX.
Sunil,
You can save Creo files as NX using File > Save as NX. However type Nx is license feature. If you have license for Collaboration_Ext_NX you can save files as NX.
Sunil,
Did you manage to export Creo data as NX?
NX can also read Creo files, but not sure about Creo3.
It is also a licensed product like the Save_as to NX from Creo3.
Another solution could be to convert your Creo files to NX with CrossManager : http://www.datakit.com/en/cross_manager.php
It is not free either, but certainly less expensive than a Collaboration_Ext_NX license.
You should compare the two possibilities.
