how to extract bom in excel format
rhr
3-Newcomer
3-Newcomer
2 REPLIES 2
kdirth
(To:rhr)
Go to table tab.
Select table.
In the Save Table drop down select Save as CSV.
This can be opened in excel and saved as an excel file.
ssywak
(To:rhr)
Go to the TABLE tab, and then go select the table you want in the main window.  The BOM table should hi-light.
Within the "Table" group of functions, you should see "Save Table".
Within that pull-down, select "Save as CSV".   CSV is a "Comma delimited format" that is easily imported by Excel.
Save it in a smart place, remember where you saved it, and then you can actually open the CSV file (it's a choice) within Excel.  Unless you had fields with commas already IN them, you should have yourself a nice spreadsheet.  If you had some commas, you'll have to do a little clean-up.
Don't forget to save the Excel file in Excel format (assuming that's what you want), or it may just save it as a CSV file again.
