how to remove a created surface
ptc-267878
wildfire 3.0
I created an offset surface (Offset 1) so that a can make a recessed cut in a part (thicken cut) up to Offset 1 (step 1.). After making this recessed cut, is there a way to remove Offset 1? The offset surface is appearing in a 2nd part after performing a Cut Out feature (step 2.). Hiding Offset 1 in the 1st part does not seem to get rid of the surface appearing in 2nd part.
Layers, my friend....
I need to poll the audience on geometry preselecting issues. I have a huge
file that was exported out of Catia and brought into Pro as an imported
file. The part is so large, that when cruising over the geometry, the
preselecting hangs up and the graphics lag behind until all the geometry is
highlighted, this is almost unbearable let alone the brightness to one's
eyes. My question to all you folks: has anybody found a way to turn
preselecting of on one part if an asm but still have it activated for the
other parts in the asm. Currently running a 3 gb graphics card
Best regards
Kelly Gensley
Genz Design & Machine L.L.C
Box 232
Victor, Iowa 52347
Ph: 319-444-0261
Email: -
"Nothing of Value comes without being earned"-Anonymous-
We turn on/off pre-selecting all the time with ease. Use the smart filter selection drop down box and change the smart filter from "Smart" to "Annotate". This will temporarily turn off pre-selecting and makes a world of difference. Easy to change back again, too.
Bob Schwerdlin
Design Engineer,
Dukane Corp.
2900 Dukane Dr.
St. Charles, IL 60174
630-797-4974 direct
In line with Bob's comment I have mapkeys for the filters. fs for filter
smart, fa for filter annotate etc.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
