a biginner's question!
after creating a PATTERN for a geometry feature how can i undo the PATTERN command to restor the original feature?
only way i know is to delete the pattern !!!
you can right click on the pattern in the model tree and you can find the delete and delete pattern option... you can use "delete pattern" command to undo the pattern what you have done.
dinesh
