how to switch over to different templates in schematics?
msonnathi
2-Explorer
Hi Team,
where Can I check which template used for that design and how to switch over the templates?
Madhu
The tool will only show you formats that the sheet content will fit in.
As an alternative create a new sheet with the template you want and use the move to sheet tool
3 REPLIES 3
To select a different drawing template/ format in the diagramming ribbon click "Change Sheet format" and selet your new drawing template
I checked that option, it shwoing only limited options. is any alternative?
