i need to How to Enable Modelcheck Configuartion Tool Edit Config_init.mc to Accessbile
dg-2
7-Bedrock
Creo 2.0 Modelcheck.
i need to how to enable Initialization setting > Edit Config_init.mc ---- This Error Shows "File Not Accessible" how to edit this settings
Mahesh_Sharma
22-Sapphire I
(To:dg-2)
Deepak,
Open Config_init.mc externally and check if MC_AUTHORIZATION_FILE is set as yes. If it is yes, there will be file holding the list of authorized members.
manjunathrv
(To:dg-2)
You need to run Creo as administrator to access the Model check files from Creo.
