Can someone help?
For the life of me I can't figure out how to select a gap or move vertexes using the new import data doctor in WF4 M100.
I've looked over the PTC online tutorial. I don't have the files that are used in the lesson, but it doesn't look too hard. It just won't let me select anything. Even if I search for gaps it won't show up. I think there must be something simple I'm missing.
I always have to go back to WF3, import the part, zip gaps, move vertexes, whatever, even though it seems the old way is much harder to figure out, at least it works.
Dave
David,
Could it be a selection filter issue or the need to specify the "type" of entity you want to select up in the pull down menus? Just a thought....
Brad -
For what it's worth I "solidified" the terminal lug for you and uploaded it. BTW, I have 'railed' (and requested) PTC (seems like forever) to update/improve their IDD documentation and training.
~Mud Dawg
Brad -
What I did to repair the part was first delete the offending surfaces, create a boundary blend, then merge the new and existing surfaces, using IDD.
HTH
~Mud Dawg
