"Eric Mills" wrote:
You have not mentioned witch version of Intralinnk you have. If you are using the older 3x series then you will need to import the entire .proi folder. You cannot seperate the folders out. If this is the newer 8/9x series of Intralink then you will need to contact PTC to be able to recover the files. As an administrator I have made it a requirement that users checkin at least once a week just in case you lose the computer. Best of luck Eric
