import step with start parts
ptc-1140334
1-Newbie
when importing a step file that is an assembly, can you force it to use
start parts for the parts rather than blank empty parts? we don't want to
manually enter default datums and parameters.
WF2
WF3
Eric Henriksen
Entegee Engineering
Davenport IA
4 REPLIES 4
Yep.  Set this config option:
     intf_in_use_template_models yes
It'll then use your default start parts/assys as set in these options:
     template_designasm [path to start asm]
     template_solidpart [path to start part]
Doug Schaefer
LinkedIn
set "intf_in_use_template_models" to yes in your Config.pro
Brian L. Taylor
Sr. Draft/Design Engineer II
Mechanical Design Analysis Documentation
Mechanical Subsystems Directorate
Raytheon Missile Systems (RMS)
(520)545-9730
www.raytheon.com
Just curious, are there any recommendations for the start parts used for
this sort of import? I thought I was going crazy but here's what I
found out...
If I use my start part, which only has the 3 datum planes, I get this:
If don't use the start part, I get this...
The second one is obviously correct. The pain is, I have to go in and
add datums and axes to assemble parts. It's a constant problem, since I
have to use customer files for analysis.
Any suggestions?
Tony
My guess is that the start part has a different accuracy or units setting
than whatever your defaults are. STEP will convert the part differently
based on the accuracy and or units of the part it is being read into.
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
