is there a standard .dmt file with 50 basic colours
dfawkes
2-Explorer
Does anyone have a .dmt appearance file I can use? I would like to be able to down load a .dmt file that has about 50 pre loaded colours. So far I only have one colour grey and I have to make them all as I go which is slow. I use pro/engineer wildfire_4. thanks for yourtime. from David
2 REPLIES 2
Basic Creo Parametric Color Map
You can cut and paste sections of the attached file or maybe it will work as-is in WF4. You might need to set the number of colors allowed in the config.pro file.
Welcome to the forum, David.
