I am using Wildfire 4 I want to make a cut into a part by mating two parts and then subtracting the intersecting geometry from the first part. thus effectuall using the second part geometry as the cutting boundry. I believe this is done in an assembly with the first part active. A perfect fit This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
William, Edit/Component Operations/CutOut, then follow the prompts. You can do this with a temporary assembly, and you can choose whether or not changes to the original reference parts will cause updated changes to the resultant cut part. David
