hello
i want to make two bending after flat pattern
i bend first 10mm to edge and in analysys measure , measurament indicate other result
i bend next to 11 but , measurement is diferit for input data write for me
how write 10 and result be 10
tks
I suppose this comes from the bending K factor.
Anyway, I think the good way should be to model the part in the bend way then making it's flat pattern. This is the way I always do, and you'r sure to have the dimensions you want. Then Creo is here to give you the dimensions of the flat pattern. Let Creo work for you ! ![]()
Why do you start from a flat pattern ?
i start from flat pattern because :
- in reality flat pattern had some modification witch not update in drawing and i do not know where it is modification
that is reason
- some person has changed flat pattern to punching mashine and drawing do not same with it what suposed to be
tks
