To be able to show the Simplified Representation's mass in a drawing note, please follow the following steps (WF4.0)
1- Set the config.pro options "force_upd_assem_mp_in_simp_rep" to "yes" & "mass_property_calculate" to "automatic"
2- In the drawing set the wanted simplified representation as active using the menu #File #Properties> #Drawing Models> #Set/Add Rep> #Done.
3- Insert a Note for the assembly mass parameter the user defined or the system parameter (&pro_mp_mass:1)
4- Regenerate the model (#Edit> #Regenerate> #Model>#Automatic)
The note will always show the mass of the
