mass properties have not been calculated
gbon
I'm using Creo2 for a short time.
Each time I save my parts, it tells me that mass properties have not being
updated.
Is it possible to disable this message or to automatically compute mass
properties each time part is regenerated?
I've read something on this few times ago but can't find it again.
GB
c128
(To:gbon)
Hi GB.
In fact, there is the config option mass_property_calculate - set it to "automatic" and you will get exactly what you want.
HTH
Matthias.
dgschaefer
(To:gbon)
Actually, no, setting "mass_property_calculate" to "automatic" results in the message he's seeing. The mass props calculation is done automatically, but not until the second regen.
It's a bug, in my view, but I'm not sure that PTC sees it that way.
LinkedIn
