milling glass and wood
al204
hello proe users...
I´m interested in using pro / nc to create milling sequences to work with hard (heavy, dense) wood and glass (10 mm thick).
does anyone have experience programming milling sequences to work on such materials??
what should be the parameters to work efficiently with each one??
I would be using a 3-axis cnc machine, which is regularly used to mill steel and aluminum to create molds for the plastics industry.
I would need to have a clean smooth surface....almost like a polished surface....
thanks, best regards
al
0 REPLIES 0
