need help
agangadharan
need help
How many components can you restructure from the same assembly level at the same time?
StephenW
(To:agangadharan)
I don't believe there is a specific number of components that can be restructured. Usually problems occur with a parent-child relationship and that stops a restructure from working. The more components you select, the more likely you are to have reference problems that stop the restructure.
