Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Hi Folks, Once again I put on my temporary administrator hat and dust of my work to convert us to WF5 from WF4.
I have been trolling through our configs and looking to see that all that is there is relevant along with adding new stuff.
One old command I came across was the one in the subject line. Our existing setting is *number_user_colors 120*
It has been there for at least a decade, probably since we had ProE in '95, so my question is if anybody knows what it means beyond the Help =
number_user_colors 200* Specifies the maximum number of user-defined colors that are available within the Appearance Editor and the Entity Colors dialog boxes.
and the Tools/Options =
Specifies the maximum number of different wireframe colors that the display can display in the graphics area(s) at any given time
I expected there would be some pointer to what the default number is or what the range should be but am coming up empty. The 200* might be a clue but to what? Is it the maximum number?
Regards, Brent Drysdale Senior Mechanical Designer Tait Radio Communications New Zealand DDI +64 3 358 1093 www.taitradio.com
