Hi All
I working on Creo 3 build m120 can create in model exploded view but will not appear in the drawing view
Please refer to the following steps.
1. Edit position
2.Click Explode Lines , Create Cosmetic Offset Line.
( To Create Cosmetic Offset Lines =>Creo Parametric Help Center )
3.Add the offset line .
4.Add 2D Drawing View
Past discussion =>Exploded View Offset Lines not showing in Drawings
1. Edit position
They should show up when you set the view state to the explode state they are defined on. Also, insure they are not on a layer or the layer is not hidden.
