I am searching right parameters to import STEP file generated by NX. It is unable to obtain a slosed solid.
thank you for your help
Most likely, you will have to (manually) to crosslink the surface (to close the hole) ... imports are not always successful ![]()
You have to get or improve your skills in ImportDataDoctor. This tool is very powerful. Only dissapoint is that you can not save within this tool. You have to exit, save and re-enter. I told you because within this tool crashes are more frequent that in standard environment.
