parameters in mechanism connections do not update?
bp
For example:
Ive created a cylinder assembly of which all relevant dimensions are driven by a list of parameters.
Whenever I create a copy of the cilinder with new dimensions, The max extension of the rod is also parameter driven and should therefore also update when I change this length. Sadly this does not work. I can fill in the parameter (in this case: "SLAG" pardon my Dutch) and the parameter changes into the number, but will not update after.
Any ideas?
vzak
(To:MartinHanak)
That's correct suggestion Martin.
Any connection related constants are represented as "connection parameters" :. For Pin rotation axis for e.g. we have :
ROTATION1_STATIC_FRICTION
ROTATION1_KINETIC_FRICTION
ROTATION1_CONTACT_RADIUS
ROTATION1_RESTITUTION
ROTATION1_MINIMUM_LIMIT
ROTATION1_MAXIMUM_LIMIT
ROTATION1_ZERO_POSITION
So to drive connection parameter by any model parameter it will be best to create component level relation, like :
ROTATION1_ZERO_POSITION:CONN_2 = ZERO_POS_PARAM
where correct connection postfix (CONN_2) is obtained automatically when you select parameter in Relations / Insert Parameter from Name List / (select Connection subtype) / pick corresponding connection in Model Tree.
3 REPLIES 3
MartinHanak
(To:bp)
I guess that you have to define a relation, which puts model parameter value into mechanism maximum limit. Unfortunatelly I am not sure if it is possible to define such relation.
Martin Hanak
Martin Hanák
vzak
(To:MartinHanak)
bp
(To:vzak)
Cheers Vladimir,
Works like a charm.
