pipeline segments won't highlight in tree
sjohnson-2
3-Newcomer
I tried searching on this but didn't find anything.
When I am in Piping, if I select on a segment of a pipeline, it will not highlight in the tree as it did in WF4. If I select the segment and right click to "select pipeline" it still won't highlight. If I then try to delete the pipeline, it finally highlights.
If I change something like a "to port" for a hose to change the hose length manually, the pipeline updates. But I can't get the pipe/hose to select. I can pick it from the assembly tree, but to allow mouse selection I have to get out of Piping and back into regular Creo.
Any help appreciated.
Sean
This sounds like a bug to me. Please contact tech support and provide the same information as above and they willl investigate. Thanks, Jim
