piping problems
ArnoldCollett
piping problems
Creo 2.0 m090
Dell M4600 laptop
Windows 7 / 64-bit
Is anyone else having this problem?
I'm unable to select a pipe end to use as a new set start point. I'm not sure if I'm missing something or if it is just a new bug in Pro/Piping. I can select a csys.
[cid:image001.png@01CF2CA8.3DD52360] [cid:image002.png@01CF2CA8.3DD52360]
Thank you for your help,
Arnold Collett
Mechanical Designer
Space Launch System - Forward Skirt/Distributed Systems Design
Redstone Gateway (48-210)
Floor 3, Cube 3107
(phone) 256-542-6848
[Boeing_logo]
1 REPLY 1
StephenW
(To:ArnoldCollett)
I just tried it and I get a message that says Selected segment belongs to different pipe line. Select again.
Do you remember being able to do this before? I'm pretty sure I have never tried it. My creation methodology is to start on one end and go so of the way, then SET START on the other end and work back to that routing point.
