[proecam] - IBL FILES
rrich
2-Explorer
Attached are PTC's limited view on what an IBL file is and how it is
structured. I have not used one in a real long time but when I did it was
from digitized data being brought into Pro/e. The way I use to look at the
format was to export one out of Pro/e but I can not find it in wildfire 4 .
Does anyone know where they put the save curve or points as IBL file at? I
do not know if there is ways to make it spline through the points or if it
was only just line to line connect I guess you can try it and see. Any
text editor will get you what you want just type in the values. The 3
numbers 30 50 40 are the xyz coordinates of the points.
Ron
0 REPLIES 0
