prt file cannot be unbend
ahmet.gunes
Hello, the unbend command in the attached file fails. Can you help?
you cannot unbend solid geometry. Unbend command can only be applied to sheetmetal geometry. Also Unbend command can only be applied to ruled surfaces (zero Gaussian curvature).
Martin Hanák
Hi MartinHanak
Yes sheet metal I turned it but it didn't work
@ahmet.gunes wrote:
Hi MartinHanak
please send your part again. I suggest you to build the part in Sheetmetal mode. Do not convert solid geometry into sheetmetal geometry. Also do not forget that Unbend command can only be applied to ruled surfaces (surfaces with zero Gaussian curvature). Please check Gaussian curvature of your model.
Martin Hanák
My manager asked me to have the piece expanded in this way, is it possible?
