ptc_setvars.bat
rizzari
ptc_setvars.bat
What does the "ptc_setvars.bat" file do? What should be in it? I loaded Wildfire 4.0 last week and I went to postprocess a machining file and I got the error
'x86e_win64_ptc_setvars' is not recognized as an internal or external command ..................
Could not find ...\ptc_setvars.bat
Thanks for any insight.
it is created by the PTC startup script, executed and then deleted
If your tricky, you can capture it (setup special permissions on the working directory, write, modify, but NO delete)
I think it sets environment variables for the shell before Pro/E is launched
rizzari
(To:rizzari)
Thanks to Bob Frindt & Dan Wolfe and the others who responded.
original post:
Solution: Need to point to the Proe Bin directory in the
PATH environment variable
<u>Under:</u>
My Computer
Properties
Advanced
Environment Variable
