usually when i use sketcher mode, randomly in between many colour lines appear, and when i zoom in or zoom out they go but appear again after sometime. is there any way to stop this?
Hi Mahesh,
For sure! I resolved this issue by first creating a rectangular sketch which I placed at a particular angle. Then, I extruded it and added a taper to get the desired design, and then cut it. I will put this as the correct answer!
Thanks again!
I do not understand what do you want to get from your pictures. Please upload another pictures.
Martin Hanak
... and upload the model, if it is possible.
Hi Martin,
I was able to resolve the issue by applying a taper while extruding. Thanks for your answer, I'm sorry fr not getting back to you earlier as I'm not here often.
Thanks again!
Hi Purva,
Can share the information about resolving this issue and mark that as correct answer to the post.
Hi Mahesh,
Thanks again!
