"Name Already Exists" (Can you find it????)
chilehead
In the attached part, I'm converting the center axis (A_34)to a set datum, and trying to change the name to "B". I get the error: "Name Already Exists". Only problem is... it doesn't exist! At least not that I can find. I'm running Wildfire 4.0 - M180. I've attached the part if anyone would like to take a stab at it. Appreciate any input.
10 REPLIES 10
Open a new part file and copy the features over "from different model" and "independent" using new refs. This
Oh and I just realized you have features copied froman external model that is missing. There could be afeaturenamed "B"in there somewhere preventing you from using it.
Yep...it's in your copied features somewhere. I deleted the features with the external refs, copied the remaining features to a new part and named an axis to "B"
Thanx Dean... great insights into this issue. I've always known Pro/E is real "grabby" and doesn't seem to "forget" anything! Unfortunately, this part is one of a large assembly and needs the references shown here as missing. (When in assembly, they're fine.) I think I'll go ahead and just use another name for the datum axis, and press on. Thanks for digging into this though... I learned something!
Steve
bfrandsen
6-Contributor
(To:chilehead)
If the existing name comes through in a top down design Publish/Copy
Geometry fashion I use this workaround to free the name.
Rename the feature on the publish side. (B -> Brenamed)
Regenerate the Copy Geometry so the new name comes in.
The B name is now free un the Copy Geometry side and can be used.
Rename the feature on the publish side back (Brenamed -> B)
Regenerate the Copy Geometry. As B is now in use in this model, ProE will
assign default name to the incoming feature name.
The original model will be unchanged after this, so no problems against
any data management systems either.
The same method can be used for an Inheritance model if needed.
Bjarne
Steve Prout <->
14-07-2011 16:20
Please respond to
Steve Prout <->
To
cc
Subject
[proecad] - RE: "Name Already Exists" (Can you find it????)
Steve
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
Hi Bjarn,
For existing Publish/Copy features coming in, there is even a shorter way. In the target model, do Edit > Setup > Name > Other and select the item you want to rename (not the feature itself). You should get an input field in the message area. At least, this is working in WF3.
Met vriendelijke groeten, Hugo.
NV Michel Van de Wiele
Carpet and Velvet weaving machines
M. Vandewielestraat 7
8510 Marke, Belgium
TimMcLellan
6-Contributor
(To:chilehead)
I am finding Creo 1.0 Interface color scheme a bit harsh/hot.
In particular, I would like to know if there is a way to change the color
around the menus, icons, to be something other than white?
Tim McLellan
Mobius Innovation and Development, Inc.
Second that here. I have to model with a welders mask.
Steve
Stephen Seymour, MSME, P.E.
Principal Engineer
Seymour Engineering & Consulting Group, LLC
3600 NW 138th Street
Suite #102
Oklahoma City, OK 73134
Sorry for the delay in responding, vacation and all... Found this solution to this issue a while back; when you name a datum feature and then delete the feature and the name is "locked off". AND you need to USE the name for something else... typically it's something like a -A-, -B- or -C- datum... You can run a simple example by creating an extrusion with a hole in it, setting the hole axis to datum -A- then redefine the sketch, deleting the hole (and thus the axis) which will "lock off" the name -A-. If you follow the steps below, you can "free up" the name...
[cid:184292009@18072011-29ED]
The tricky part is that you HAVE to use the edit definition box to do the renaming... IF you simply select the item, RMB and hit Properties, you'll get the "name already exists" when you try to rename to the "locked off" name.
[cid:184292009@18072011-29F4]
And then select the properties tab:
[cid:184292009@18072011-29FB]
I got this to work just as described. It seems to "flush" the name that's locked up out of the system so you can use it where you NEED to.
Pass this along to whomever you think might need it...
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
dbowles
(To:chilehead)
FYI
The solution attached worked for us
Douglas K. Bowles
Advanced Systems Harn/Des
520-665-7082 Office
520-490-9395 Cell
PRIVACY ACT NOTICE: This communication may contain privileged or other
Official information. If you are not the intended recipient or believe
that you have received this communication in error, please reply to the
sender indicating that fact and delete the copy you received. It is a
violation of Federal Law to print, copy, retransmit, disseminate, or
otherwise use this information without prior authorization.
----- Forwarded by Douglas K Bowles/US/Raytheon on 07/18/2011 09:02 AM
