Since we upgraded to WF5, it seems that the "Move to View" icon is always greyed out (or unavailable when right clicking) when I need it. Yes, I have the Annotate tab selected. I used to use it in WF2 & 3 so I'm familiar with it's limitations. Has anyone else had a problem? Know somethin I don't know? I use it to move notes or dimensions to and from views such as a detail to a parent. Thanks for the help!
Clint,
If you select the dimension and RMB click to bring up the context-sensitive menu, you will see the option to move to other view. Just select the command from the menu and select the view that you what the dimension to go.
K.
That's how it should work but when I right click, the menu comes up but there is no Move to View option. I can't use the icon either cause it's grayed out. Seems like I've had the problem since WF5.
