random pattern
gbon
random pattern
Hi alls,
I'm wondering if it would be possible to modeling a kind of random pattern.
The aim is to make random holes in a sheetmetal part (varying diameters and
positions).
However, distance between 2 holes must be few millimeters so it's not
completely random pattern.
Any idea on how to do this ?
GB
bokm9606
(To:gbon)
Pattern table?
cdspk
(To:gbon)
Create a uniform pattern BUT make sure the instances are in a Group, then right click on the pattern and you will have the option Unpattern, shift select all the groups and Ungroup if needed, now all the instances are independent features.
I used this method recently to create an Aero chocolate bar style pattern (you have Aero in the US?) - random hemisphere cuts into a surface.
iceblink1
(To:gbon)
I would think the best way to do it is to do a bit of programming in
your favorite programming language, and then use a pattern table in the
Pro/E model. I think you will quickly run into limitations within Pro/E
if you wish to check for overlapping circles etc. (Does Pro/E even have
a random() function?)
A simpler way of doing it: create an excel sheet with random positions
and diameters, and then simply remove the overlapping circles by hand.
Then put the result into the hole table.
Best regards,
Patrick Asselman
